6
After 15 years of use, one of my Alps mechanical selector switches (metal contact spring dragging across metal tracks) had developed oxidised/dirty contacts.
After some cleaning with alcohol and Kontakt 60 the contacts are once more shiny and the switch is ready to be reassembled. - Just one last issue: should the contact spring which drags across the contact tracks be lubricated or protected against moisture?
If yes, using what? Silicone oil/grease, WD 40, watchmaker's oil? Or is keeping everything dry and clean best?
  • \$\begingroup\$ Do you have any pictures? For all things in contact (electrical and mechanical) with the rotating assembly, what materials are they made of? \$\endgroup\$
    – shimofuri
    Commented Sep 12, 2013 at 0:55
If you're worried about corrosion, you could use some form of bulb grease in a very small quantity.
Personally, I would only apply the grease if the device operates in an environment with high humidity or big temperature changes AND is exposed to ambient air.
When I used to maintain the old Strowger telephone system, we applied a light oil to the contacts of the two-motion selectors and uniselectors. I assume the reason was to reduce wear on the contact banks.
