12
I want to display a 4 digit number on a small device that fits in a hand. I have a CR2032 3V battery at around 230mA, my microprocessor is a 8051 (in a BLE112) usually uses about 0.9µA and I want the device to last as long as possible.
I've looked at the typical seven segment displays, which typically uses a few mA which is too much.
A alternative is the Sharp LS013B7DH01 which is used in Pebble and uses 5 µA, but seems a bit complex for my microprocessor (and expensive)?
There should be some simple low power 7 segment display which has a average power consumption measured in µA (not mA), but I simply can't find it or think of some other solution.
What alternatives do I have?
  • \$\begingroup\$ How often does the value change? \$\endgroup\$ Commented Oct 11, 2013 at 9:20
  • \$\begingroup\$ When in use, a few times per minute \$\endgroup\$
    – Hink
    Commented Oct 11, 2013 at 9:37
12
LCD display without back-light is the only possible solution on these conditions.
Something like this:
Here is some example data sheet: Link to PDF
  • \$\begingroup\$ Nice, how much energy would it use? \$\endgroup\$
    – Hink
    Commented Oct 11, 2013 at 9:36
    \$\begingroup\$ @Hink - probably several uA. \$\endgroup\$
    – johnfound
  • \$\begingroup\$ How would I drive it with a 3V (DC) coincell battery in a power efficient way? I found out that I need some separate driver chip which can alternate the current. Preferably I would like to just input numbers via SPI, I2C etc. \$\endgroup\$
    – Hink
    Commented Oct 22, 2013 at 16:22
    \$\begingroup\$ @Hink - but you can generate AC with the outputs of the uC. But IMO, how to do so is a little bit offtopic in this answer. Maybe you have to ask another question about how to control LCD display. \$\endgroup\$
    – johnfound
    Commented Oct 22, 2013 at 17:12
    \$\begingroup\$ Note that you need a minimum of 1 + (7 * 4) = 29 outputs to drive a static 7-segment 4-digit display (no decimal points or colon) as in the linked datasheet. One output drives the backplane (common) plus you need one for each segment. \$\endgroup\$ Commented Oct 23, 2014 at 20:49
E-paper displays "stick" at the last value displayed, and only use power to change: http://www.eink.com/
They're a bit of a hassle to drive, and expensive.
Sarkfun used to sell a small E-paper display. https://www.sparkfun.com/products/retired/10150
Perhaps you can locate a different widget vendor for the same.
