I have a linear peristaltic pump (salvaged from medical equip. - likely used for dosing, etc). It uses a stepper motor and an optical shaft encoder. I have the motor working but I am confused about getting the wiring for the encoder sorted out. I've already done a search on the number appearing on the part and got no hits.
This is probably very simple - there are 4 wires: red, black, green and white. I don't want to blow the encoder out so I thought I would ask here. Can I assume that:
- red Vcc 5v
- black: gnd
- green: channel A
- white: channel B
I'll be using this with an arduino - so would I need pull up (or down) resistors on the signal lines? And if I can't assume the above, is there a way I can determine how to wire this up?
And finally, the encoder wheel has two slots in it - and I am trying to figure out what they mean in terms of pump state. Finding initial position at start? Or pump compression state.
