I am trying to create a custom library part in Eagle and I am having trouble scripting vias. I get an error saying that vias can only be created for boards. However I can manually place them with my mouse.
1\$\begingroup\$ This question appears to be off-topic because it is not about electronic design. \$\endgroup\$– Leon HellerCommented Jul 31, 2014 at 16:05
4\$\begingroup\$ @Leon I disagree. Designing parts in Eagle (or any schematic/PCB software) is definitely part of electronic design. \$\endgroup\$– JYeltonCommented Jul 31, 2014 at 16:21
\$\begingroup\$ Please elaborate on what you mean by "scripting vias". \$\endgroup\$– Dan LaksCommented Jul 31, 2014 at 16:47
\$\begingroup\$ using the command line and typing "VIA diameter location" will not work in the library designer. I can however use the mouse and place them. I need to place dozens of them at precise locations so its tough to use a mouse. It gives me an error saying I can place VIAs in the board designer window on a project when using the command line. \$\endgroup\$– user1978109Commented Aug 1, 2014 at 16:37
Add a comment
1 Answer
Yes you cannot place vias in a package design.
Instead of it you can use pads with different shapes.
You can use the tool on the left or you can use the command like this:
PAD [diameter] [shape]
For a round pad (like a via) you can type:
pad 1.2mm round
