So I was thinking about making a basic Highpass filter. I was wondering if there was any reason to use an RL configuration as opposed to a CR configuration.
Your question touches another question: "What is the advantage of active RC filters if compared with passive RLC topologies?".
Answer: One of the advantages is the avoidance of inductors because inductors (if compared with capacitors) have larger dimensions and more weight and tuning is problematic. More than that, they are more expansive and have very bad EMC capabilities (they are "good" antennas) and their IC-capabilities are limited.
For these reasons methods have been developped to realize active inductances (opamp-based RC circuits) or to replace inductances in passive RLC circuits with resistors applying the so-called "Bruton transformation".
However, for high frequencies inductances are still be used due to the limited frequency capabilities of opamps.
Usually capacitors are more accurate and more ideal than inductors, as well as being cheaper.
For example, in the case of your high pass filter the stop band attenuation will be limited by the inductor series resistance (RL) or the capacitor leakage (RC).
There might be exceptions for high current and/or very low impedance, or extremely high frequencies.
