I know the question sounds simple, but I am facing an edge case here. I have a microcontroller with 3.3V on the GPIO's. I want to use it with this LCD panel. Adafruit creates their own breakout board, but I would like better speed/color depth so I am making my own board to support the 8080 MCU 18-bit parallel interface.
The LCD has the following stats for voltage:
VCC
Recommended - Min: 2.5 Typ: 2.8V Max: 3.3V
Absolute Max - 4.6V
Backlight
Recommended - Min: - Typ: 3.2V Max: 3.4V
Now I know i can use 3.3V on the backlight, but I am a little worried about using 3.3V directly on the VCC pins. Do you think I need a level shifter? Explain your reasoning.
