Having no knowledge of electricals, I am interested in learning the applications of Nichrome.
I understand it has swg ratings. But what I am looking for is a formula that can calculate a particular thing if other certain inputs are provided.
Like the V = I/R triangle, is there a formula for Nichrome containing the following propreties:
Voltage, Amperage, Temperature of Nichrome, Length of Nichrome wire and Rating of Nichrome wire (swg) - I believe these are all the variables applicable, please correct me if I am wrong.
Example 1: So for instance, if I input the Temperature of the Nichrome I want to achieve, say 50C celius, the length of the Nichrome wire to be 2 Inches and the 32 swg rating, using these, can the formula calculate the voltage and amperage requirements?
Example 2: Using the inputs, voltage, amperage, length of wire and swg rating, can it calculate the temperature?
Thanks
