I have 9 3w leds (white) and 2 1w leds (blue). I have one led driver with sufficient output to drive only the white leds (either in series or parallel.) Therefore, I figured I will get a separate driver for the blues(which have a much lower total power requirement than the whites.) With a 3 position switch, i would like to have:
Position 1 - both white and blue leds on.
Position 2 - all lights off.
Position 3 - blue lights only on.
This seems like it should be simple. Any direction on learning how to do this would be welcomed.
Thank you.
