I'm new here, but I've been checking your forum few times before, never registered. Anyway... I have a problem at my home. I'm not very electrical kind of guy, so these questions may be easy to answer to some with more experience in this field.
I bought a 5730 LED lights from eBay, of consumption stated at 2W per light bulb. I have 19 bulbs installed and are all wired to an adapter. The consumption when first installed was around 42-45W. But now, after two weeks use (may have happened even earlier) the lights are consuming 70W!
What is going on?! How could this be?!
Thanks to anyone who could help me out
OK, I'm not sure what info I have to give, please do understand I'm not good with this stuff. But here is goes in my own words, very amateurish discription:
Led are like this: Base: G4
Led type: 5730 5630
Input: AC 12V
Power: 2W
Color: pure white (6500-7000K)
Lighbulb consists of 15 x 5730 LED
I wired all of them (19) to an adapter (12V, 5.8A). I wired them like this: I took a wire and went from adapters wire + to lighbulb wire +, then to next lightbulb etc. I did the sam procedure with - polarity.
To measure the usage I used a wattmeter, commercial one you put in the socket and then you plug in device switch to show you Watt usage and that's it. When I first pluged it in it showed 40-45W. That's ok. Then when I tested it 2 weeks later 70-75W. That's not OK :( I'm from EU.
