6
I've put a small battery powered commercial radio inside a Quality Street tin. The tin is all metal with rolled joints and the lid is a tight fit. I'd be willing to bet that there are no holes greater than 0.1mm around the lid's closure. It's a fairly common Sony ICFS22 FM/AM Pocket Radio with a telescopic aerial, and the tin is approximately 300mm in diameter.
Why does the radio work when receiving an AM station (1 MHz), but only produces static when switched to FM (100 MHz)?
Some further details of things I've done...
The tin IS magnetic, attracting a magnet well
The walls are 0.25mm thick (including paint)
The inside of the tin is unpainted
I grounded the tin to the earth wire from a UK mains electrical socket, and repeated the reception test. I filed off the paint where the wire touched the tin. Results:-
FM: Total static. No discernible change with /without earth wire.
AM: Tinny but recognisable radio station. No, repeat no discernible change in pitch or volume with /without earth wire. Surprised.
The tin with the ground wire... Grounded tin
  • \$\begingroup\$ I'm actually trying to produce a pure static noise source. I take it then that a belt and braces approach would be to operate the radio on FM, 'upgrade' the tin to continuously soldered copper sheet and make it thicker... \$\endgroup\$
    – Paul Uszak
    Commented Jun 7, 2015 at 1:46
Normally AM radios use a magnetic loop (ferrite rod antenna) for picking up the H field part of the electromagnetic wave they are trying to receive: -
A closed box of steel isn't going to substantially prevent the H field penetrating inside. Think about the fact that you can extend the range of a magnet by putting some iron on one of the poles. If it were mu metal (rather than steel) the eddy currents set up might start to substantially reduce the H field of course.
An FM radio probably uses a short dipole (to be able to place it inside the chocolate box tin) and significantly this receives the electric field part of the EM wave so, the box is acting like a faraday cage and blocking the signal. A short dipole is also not going to naturally pick up anything like the sort of signal needed - typically a quarter wave at 100MHz is 0.75 metres and if choc boxes were that sort of size I'd be impressed!
Having said all of that, my answer is only justifying the facts as stated in the question. If someone asked what would happen if a radio were placed inside a choc box tin I'd still mention the H field and E field reception stuff but, intuitively, I wouldn't be able to make a call on it one way or the other.
  • \$\begingroup\$ I'm going to ground the box tomorrow to see if that kills the AM reception... \$\endgroup\$
    – Paul Uszak
    Commented Jun 8, 2015 at 1:01
  • \$\begingroup\$ @PaulUszak, if the box allows the H field thru then grounding it will have zero effect - that's my belief about what is happening and I look forward to hearing what happens. \$\endgroup\$
    Commented Jun 8, 2015 at 7:39
  • \$\begingroup\$ @PaulUszak did you ground the box - did it make a difference? Are you able to formally accept one of these answers? \$\endgroup\$
    Commented Dec 7, 2016 at 14:25
  • \$\begingroup\$ Yes I did, and I edited my question on that basis for future readers. In short, it made NO difference on either AM or FM bands! \$\endgroup\$
    – Paul Uszak
    Commented Dec 7, 2016 at 14:32
  • \$\begingroup\$ My answer then was correct in your eyes or not? \$\endgroup\$
    Commented Dec 7, 2016 at 14:43
It's because of the thickness and the type of metal, as well as the signal type.
EDIT: NOTE: Upon further thought it needs to be stated here that various different metals have very excitocally different noise rejection curves, so generally copper or aliminium may not be better in all cases, they may even be worse. The central point to the answer remains largely in tact, though.
If your tin were made of copper or aluminium it's possible AM would have been reduced enough to be unusable, but the tin is made of a specific type of alloy that may or may not be working as well as a shield. (As per the comments, it turns out it may be better, but that doesn't change the remaining point:)
The higher the wave frequency is, the thinner the metal sheet can be to keep it out/reflect it. This comes from EM-field theory, but within usable parameters it is generally true that a thinner sheet of metal will work better for high frequencies than low frequencies. The thickness then defines at what frequency you "stop hearing" anything. There are some exceptions for hair-thin sheets and certain types of waves or frequencies, but you can ignore those for now.
Apart from that, an AM signal is a wave that is stronger and weaker in the frequency of the sound. AM stands for Amplitude Modulated/Modulation. So the signal gets weaker and stronger to identify the audio wave. Because that system is very sensitive to the signal strength to supply audio, there's an auto-gain control on it, that tries to amplify it.
So there is some signal left, because the tin is just about thin enough to let some AM frequencies through, and then the Auto-Gain tries to make something of it by amplifying it till it makes some semblance of the original audio.
As an experiment you could try wrapping the radio (in a plastic bag, so you can't accidentally cheat by modifying the antenna) in thin tinfoil, or other thicker and thinner metals and see which waves stop working when.
    \$\begingroup\$ A chocolate can is generally made out of steel, probably nickel-plated. \$\endgroup\$ Commented Jun 7, 2015 at 1:06
    \$\begingroup\$ @WhatRoughBeast while that does fit my story, it did make me think back a bit to SAE steel types and their curves, which led to my edit/note. Thanks for that. The major point still stays that the frequency vs thickness vs metal type has many influences. \$\endgroup\$
    – Asmyldof
    Commented Jun 7, 2015 at 1:16
  • \$\begingroup\$ While I didn't mention it (it seemed pretty obvious) steel has rather poor conductivity, roughly an order of magnitude less than copper. \$\endgroup\$ Commented Jun 7, 2015 at 1:33
    \$\begingroup\$ @WhatRoughBeast But it is ferromagnetic, which puts it in a whole new ballpark, especially for below-microwave. I thought you were hinting at that. \$\endgroup\$
    – Asmyldof
    Commented Jun 7, 2015 at 1:35
    \$\begingroup\$ Never mind all this speculation, clearly what the OP must now do is purchase a tin of Roses and a tin of Heroes and a tin of Celebrations, plus a Family Circle biscuit selection, and conduct in-depth experiments on all of them in combination with some sort of electrical water heating device and a family pack of teabags. FOR SCIENCE! \$\endgroup\$
    – John U
    Commented Jun 8, 2015 at 12:35
