I learned that either positive or negative feedback on an op-amp makes voltages at a noninverting input and an inverting input same.
Then, I think I don't need to care about absolute maximum value of differential input voltage. Is it right?
I have TL972IP and I am trying to convert a bipolar sqaure wave into a unipolar square wave swining 0 V and 5 V.
And I have to determine an amplitude of the input square wave. As regarding the absolute maximum value, a signal will swing -0.4 V and +0.4 V.
But, if my guess--the absolute maximum value can be bypassed, ignored with feedback--is right, I can increase the amplitude a little bit more, from +- 0.4 V to +- 1 V.
By doing this, I can reduce the gain, which results in increase of bandwidth since GBWP = Gain * BW and it is constant.
ADDED
In the case above, I think V+ and V- will be the same. Then the differential input voltage will be zero. Thus, I don't need to care about the absolute maximum rating of the differential input voltage. I only need to care about other ratings and conditions. Is that right?
