I have:
- 2 8x8 LED Matrix, and
- a MAX7219 Chip.
Q: I just wonder how can I connect that to the Arduino Duemilanove?
I have been googling but I couldn't find out how.
I have:
Bryan Chung had a tutorial still available on the Internet Archive on how to connect a LED Matrix to an Arduino using a MAX7219:
Here is an experiment with an 8×8 LED matrix, driven by a MAX7219 IC, controlled through an Arduino micro-controller board. A custom PCB has been made by Tan from DinoTech to tidy up all the wires connecting the LED matrix and the IC. It comes with a separate 12V power supply, in order not to drain everything from the Arduino board.
Only 4 wires are necessary to control the MAX7219 driver IC. They are the
Data Clock Latch/load Ground
The data and clock pins should match those for the shiftOut() command in Arduino. The latch pin will give a LOW to HIGH pulse after the shiftOut command. I have written the original program for Javelin Stamp. Since Arduino can only shift 8 bits of data, I have to use 2 separate commands to shift both the upper and lower bytes to the MAX7219, which needs a 2 bytes control for each command.
For the data structure of the 8×8 LED matrix, I use a byte array – matrix of length 8. Each row in the matrix corresponds to the Y dimension. Each bit in a row corresponds to the X dimension. Digit 1 is on; 0 is off. The X direction is reversed and there is also an 1 bit shift. The updateLED() function caters for this.
The first program is an animation of a single line motion.
int CLOCK = 12;
int LATCH = 13;
int DATA = 11;
byte matrix[8];
int idx = 0;
void setup() {
pinMode(CLOCK, OUTPUT);
pinMode(LATCH, OUTPUT);
pinMode(DATA, OUTPUT);
digitalWrite(CLOCK, LOW);
digitalWrite(LATCH, LOW);
digitalWrite(DATA, LOW);
initLED();
clearLED();
void loop() {
for (int j=0;j<8;j++) {
updateLED(idx, j, true);
refreshLED();
delay(200);
updateLED(idx, j, false);
refreshLED();
delay(100);
idx++;
idx %= 8;
void ledOut(int n) {
shiftOut(DATA, CLOCK, MSBFIRST, (n>>8));
shiftOut(DATA, CLOCK, MSBFIRST, (n));
digitalWrite(LATCH, HIGH);
delay(1);
void initLED() {
ledOut(0x0B07);
ledOut(0x0A0C);
ledOut(0x0900);
ledOut(0x0C01);
void clearLED() {
for (int i=0;i<8;i++) {
matrix[i] = 0x00;
refreshLED();
void refreshLED() {
int n1, n2, n3;
n1 = i+1;
n2 = matrix[i];
n3 = (n1<<8)+n2;
ledOut(n3);
void updateLED(int i, int j, boolean b) {
int t = 1;
int n = 0;
int m = 0;
if (j==0) {
m = 7;
else {
m = j-1;
n = t<<m;
if (b) {
matrix[i] = n | matrix[i];
else {
n = ~n;
matrix[i] = n & matrix[i];
Sorry if it's a bit late for you, but I've just written a post about using the MAX7219 with LED matrices and 7-segment LED Displays.
