I'm trying to write up a lab report, but no one seems to be able to give me an answer for what the incremental resistance of a BJT means, or why it's significant so I'm hoping someone here can tell me. In our lab, we first built a DC circuit, pictured below:
First Circuit (DC)
We measured the incremental resistance by calculating Delta(Vy)/Delta(Iy) at different Iy values (10 uA, 100 uA, and 1000 uA).
Then, we built a second circuit, this time with an AC component:
We measured the incremental resistance again, this time with a more complicated formula, and the incremental resistance changed - a good amount, but it was still on the same magnitude as measured before.
I hope I'm not being ignorant by asking, but I truly do not understand the purpose of this laboratory and no one seems to be able to tell me - even the TAs. I'm assuming there must be some theoretical difference in the incremental resistance between AC and DC circuits, but I don't know what the theoretical explanation is. Additionally, I don't know what the significance of the incremental resistance is and/or what the "theoretical" incremental resistance should be for these two circuits. I'm not sure if I provided enough detail, but I'm really just looking for a good explanation of incremental resistance.
The problem touches the question: Can there be a difference between both measurements because the "incremental" resistances are not equal? It think, the only differences can only be caused by
(a) thermal properties and/or
(b) capacitive properties of the pn junction.
In this context, the measurement times (first experiment) and the test frequency (second experiment) are important parameters.
