I am using this mosfet driver Intersil HIP2101. I have soldered a bootstrap capacitor to HB and HS of 100nF, a standard 100nF for supply stabilization and a 100kOhm resistor to HS and VSS. Now If I apply a PWM signal of 3.3Vp-p 200khz 50% duty cycle this is my signal:
Why is the voltage from t(0-ton) decreasing? The IC is meant for operating as a half bridge driver but I only have one PWM generator. Is this the problem or does it have another cause?
Schematic:
