Sample voltage divider circuit:
In this circuit, \$Vout\$ is, by Ohm's Law: $$ Vin * \frac{R2}{R1+R2} $$
But this circuit, by itself is pretty much useless right? That is: If we don't connect \$Vout\$ to a load, then there is no reason to divide a voltage. So a better representation might be:
But in this circuit, \$Vout\$ is, by Ohm's Law:
$$ Vin * \frac{Rload*R2}{R1*R2+Rload*(R1+R2)} $$
So why isn't a voltage divider circuit formula stated as the second version, rather than the first one?
