I'm having trouble to identify this bad boy:
cap
'680' or '089' i don't even know how to read it. Can someone give me the value ?
I used a Chinese T4 LCR on it and according to the result the value is 61/62 pF
What the difference between this next capacitor (except value) and the previous one if there is any?
cap2
    \$\begingroup\$ 680 is a standard value, 68*(10**0) pF. 089 is not. \$\endgroup\$
    – Grabul
    Commented Mar 7, 2016 at 19:25
  • \$\begingroup\$ +/- 10% is a reasonably normal tolerance for capacitors. Not accounting for the meter you used. 68pF is what I would expect from the print. \$\endgroup\$
    – jippie
    Commented Mar 7, 2016 at 19:47
Your LCR is not lying to you (much).
680 translates to 68x100 and is given in units of pf.
So 680 = 68pF
There is no difference in capacitance value between those 2 examples, they're both 68pF but the orange/brown one doesn't explicitly specify the 0.
    \$\begingroup\$ Reference: for aluminum electrolytics (and tantalums, I suppose), the value is usually in microfarads. \$\endgroup\$
    – user65586
    Commented Mar 7, 2016 at 19:31
