For one of my projects I need to glue a (sideglow) fiber cable to an LED.
I have never done something like this before, therefore I wanted to know if you have any experience on how to do that and how not to do that.
I would use (transparent) epoxy glue. Is this a good choice?
Is a 3mm LED big enough for a cable with 3 mm diameter?
Should I "pretreat" the LED somehow (maybe drill a hole or cut the "cap" to make it flat) or is it possible to fill the gap with epoxy?
Some of my further considerations that I have arrived at are as follows:
Whatever kind of glue one uses, it will never transport light as good as air. This is why I think it would be the best option to use a tube and put the led and the fiber cable inside. I would then glue the fiber and the led to the tube (and probably use hot glue, but epoxy may be even better).
[edit]
Don't want to have this question unanswered at all, therefore I share some of my further considerations:
