Roman Black's designs are always very tense — highly optimized and reduced to the minimum set of components that will do the job.
In this case, however, the inductor is working the same as in any boost converter: When Q1 switches on, L1 is "charged" with current for a time, and then when Q1 switches off, the stored energy causes the voltage at point A
to rise until D1 conducts and passes the current to CLOAD.
The oscillator (Q1 and Q2 together) runs at a fixed frequency and fixed duty cycle, always drawing the same amount of power from the source. Regulation is achieved by putting a shunt zener across the output, where it dissipates any power not consumed by the load.
Brief description of oscillator operation:
- When power is first applied, Q1 turns on and Q2 is off.
- Current through L1 and Q1 ramps up, and so does the voltage across R2.
- When the base voltage of Q2 rises high enough, it begins to turn on.
- Q2 turning on reduces the base drive to Q1, causing it to cut off.
- Q1 cutting off causes the voltage at point
A
to rise because of the energy stored in L1.
- The voltage at point
A
provides positive feedback to Q2 (via R4) to keep it turned on even though the voltage across R2 has dropped.
- D1 conducts and current flows into CLOAD. The current through L1 ramps down.
- When the current through L1 and D1 drops to zero, the voltage at point
A
drops again, causing the base voltage of Q2 to drop as well.
- As Q2 begins to cut off, Q1 begins to turn on. This causes the voltage at point
A
to drop all the way to zero, turning off Q2 completely and bringing the circuit back to the initial state, where the entire cycle repeats.
The on time of Q1 is primarily determined by the supply voltage, the value of L1, and the resistance of the charging path (L1, Q1 and R2).
The off time is primarily determined by the output voltage (relative to the input voltage) and the value of L1.
Both times are influenced to some degree by the time constant associated with R3 and C1.
