Could someone please give me some hints/point me in the right direction as to how to find Vout for the circuit below
1 Answer
Calculate the voltage on the opamp's non-inverting input in a straightforward way, then use your knowledge of the rest of the configuration to relate VOUT to that.
\$\begingroup\$ @ jp314 Could you please tell if this is right: V(+)= V(in) * R/(R-jXc) and Xc=1/(wc) . \$\endgroup\$ Commented Apr 25, 2016 at 4:49
\$\begingroup\$ it is correct. Standard notation is Xc = 1/(jwC), which is also -j/(wC) \$\endgroup\$– jp314Commented Apr 25, 2016 at 4:58
