I want design a dimmer circuit that have output voltage of 0-380V(rms). I didnt see any application about 380 V dimmer circuits and there is no information about 380V application in MOC series opto datasheets. But some optotriacs allow application for 380 V such that VO3062 or IL410 in their datasheets.
The 380 V (single phase) is produced from 220 to 380V transformer in my application. I have designed a dimmer circuit for 0-220V before and it worked perfectly. This circuit is below. I want use again these components and this circuit.
But now I want control 0-380 V output and I dont know what will be resistors of circuits. I think they will not change because of resistor value is related with input voltage of MOC3061 (VCC is 5V and current must be 15 mA for MOC3061 series ). Can I use again MOC3061 and BT137 for control of 0-380 V dimmer circuit?
