I saw a circuit that power series a RC parallel circuit, please refer its circuit picture as in the below.
My questions is, 1). Is it a filter? 2). What is its purpose? 3). What is its theory?
Kind regard, Zu Wang.
  • \$\begingroup\$ Looks like a high pass filter with NON-ZERO low frequency gain. \$\endgroup\$
    – rsg1710
    Commented Nov 10, 2017 at 8:10
If we assume the system offers a resistive loading your circuit, \$R_2\$, then yes, it looks like a band-pass filter featuring a zero and a pole. The transfer function of such simple 1st-order circuit (1 energy-storing element, capacitor \$C_1\$) can be determined using the FACTs without writing a line of algebra. First, draw the circuit for \$s=0\$: open the cap, the transfer function is given by the resistive divider: \$H_0=\frac{R_2}{R_1+R_2}\$.
Now, reduce the excitation voltage to 0: replace the input voltage source by a short circuit and "look" at the resistance offered by the capacitor's connecting terminals when it is temporarily removed from the circuit. If you look at the below sketch, you see \$R_1||R_2\$ and the first time constant \$\tau_1=C_1(R_1||R_2)\$. In a 1st-order circuit, the pole is the inverse of the time constant thus: \$\omega_p=\frac{1}{C_1(R_1||R_2)}\$.
For the zero, it requires a bit of abstraction: what in this circuit could prevent the excitation from reaching the output for a certain value of \$s\$? If the impedance made of \$C_1\$ and \$R_1\$ in parallel approaches infinity at the zero frequency, then there is no response. We can write \$Z_1(s)=\frac{1}{sC_1}||R_1=R_1\frac{N(s)}{1+sR_1C_1}\$. This expression features a pole (which makes it go infinite) and it is the zero of our system: \$\omega_z=\frac{1}{R_1C_1}\$. The complete transfer function can thus be expressed as \$H(s)=H_0\frac{1+\frac{1}{\omega_z}}{1+\frac{s}{\omega_p}}\$. The below Mathcad sheet shows the resulting dynamic response:
I did not write a line of algebra and in case I made a mistake (for instance if I see a deviation between the derived expression and the raw expression \$H_{ref}\$ in the above picture, then I can easily fix the guilty intermediate step. This extremely useful and unbeatable when dealing with higher-order circuits.
For a fast analysis you can build the model in LTspice. I made this for your and attached the resulting frequency-gain-chart. Chart 1
As you can see, this filter acts as band pass. Thus only a certain bandwidth can pass the filter. For further information to this type of filter just search yourself. One should also mention that this is a very bad filter, because the attenuation in the non-pass range is very very low compared with the pass range (-100µdB vs. 80µdB).
  • \$\begingroup\$ What did you consider load as? \$\endgroup\$
    – rsg1710
    Commented Nov 10, 2017 at 9:38
  • \$\begingroup\$ can you share schematic of your test circuit? \$\endgroup\$
    – rsg1710
    Commented Nov 10, 2017 at 9:41
  • \$\begingroup\$ A 1MEG resistor \$\endgroup\$
    – auoa
    \$\begingroup\$ I think this result is simulator depended; even then its difficult to conclude that it doesnt pass anything. In fact it passes everything the number says, the value is very very very close to 0 dB at any frequency meaning the output is approximately input itself . Think it this way at low frequency the resistor provides the path and at high frequency the capacitance. So I dont see why it will not pass in any frequency. \$\endgroup\$
    – rsg1710
    Commented Nov 10, 2017 at 9:50
    \$\begingroup\$ It's not a bandpass, but a shelf-highpass. You probably considered the shape of the phase instead of the magnitude. \$\endgroup\$ Commented Nov 11, 2017 at 8:08
