I set 12V adapter to 5V absolutely in a wrong way.
So it's been subject to undervoltage? Outsourced guessing isn't a very productive troubleshooting strategy, but I'll bite.
I assume you meant that you applied 12v to the 5v input. If that's the case, the AVR micro is probably dead. The FT232 (or whatever constitutes the SMT serial-usb bridge on the bottom-side) is probably dead. The L298 might have survived, but it would be a miracle. The unknown PDIP-8 and TO92 packages are a mystery.
Start by creating a problem description. Are there any observed symptoms? What does it do or not do which constitutes incorrect behavior? What tests have been attempted? What was the nature of the voltage mismatch? Was it overvoltage? Improper sequencing? Reverse polarity? Was it applied for seconds or hours?
