I am trying to use a Photocoupler 4N-25 with an arduino uno r3.
I connected the collector to +5volts and the emitter to ditital pin 0.
Now, since there is no voltage applied to the gate and I haven't even connected the other side of the photocoupler (diode) with anything. Shouldn't it have an indication of LOW in the serial monitor? Instead it fluctuates between 0's and 1's.
I also gave it a try with the gate grounded, nothing...
I tried with a resistor to limit the current to the arduino, nothing...
Any suggestions?
EDIT
By trying out the circuit of @Passerby the input pin was high. when i turned the gate High the pin went low. All is good so far.
what i want now is this depicted below.
when i replace the opto-isolator with a simple led (D1) it works. i tried it out.
The problem now is that the led in the opto-isolator is not bringing the gate high. why is this happening.
keep in mind that i only want to use this opto-isolator for this circuit.
and correction the capacitor is 150nF
  • \$\begingroup\$ You should have pinMode(0,INPUT_PULLUP) and not pinMode(0,INPUT) in your setup() \$\endgroup\$
    – Roger C.
    Commented Jun 5, 2016 at 19:36
    \$\begingroup\$ This is not a forum but a Q&A site. Please don't change the question after it has been answered; if you have a new question, ask a new question. \$\endgroup\$
    – CL.
    Commented Jun 5, 2016 at 20:52
  • \$\begingroup\$ You have not accounted for both AC cycles, and have probably killed your diodes or your optocoupler. Put another 1N4148 in parallel with the 2 you have, but reversed. And for God's sake reduce your capacitor to 1 uF or less. \$\endgroup\$ Commented Jun 5, 2016 at 20:57
  • \$\begingroup\$ since the vf of the photocoupler led is 1.4 v and 10mA. then R (instead of a capacitor) would be 22000 ohms. if you set R as the reactance Xc with frequency 50hz and solve for C = 145nF~150nF. it works for a normal LED why not for a photocouplers LED of same specs? \$\endgroup\$ Commented Jun 5, 2016 at 21:08
Typical wiring for a on/off digital signal from an optocoupler is this:
Pull-up to VCC, most likely 5V for most Uno R3. The pull-up gives it a known state of HIGH when the optocoupler's LED isn't on. When the LED is on, the optocoupler's transistor turns on, pulling the collector towards ground, giving a LOW signal.
Alternatively, wire the collector to the GPIO with the pinMode(x,INPUT_PULLUP) mode enable, using the internal ~47kΩ pull-up resistor. Essentially the same thing.
This is a typical open-collector setup for digital logic.
The Way you had it connected, with the emitter to the GPIO, is a emitter follower, and will show either 5V when the LED is ON or FLOATING when the LED is OFF. A Floating input will not have a fixed state, and will float between states, like an antenna. Use the wiring above instead.
  • \$\begingroup\$ the two diodes in series are there to bring the forward to 1.4 volts. The circuit works with an led. \$\endgroup\$ Commented Jun 5, 2016 at 20:09
