I have bought a beautiful old radio, which I'm trying to convert into a DAB radio (there's no future for FM radio in my country).
Of course I could just use a DAB receiver, plug it into the old radio's speakers, and be done, but there's no fun in that. Instead, I want to be able to operate the old radio, turning its knobs and pressing its buttons. So that when I turn the tuning knob, I'm switching between DAB stations instead of tuning between FM frequencies.
The first step (at which I'm stuck) is to translate the position of the tuning knob (A) into a digital value I can use to control a DAB receiver. I'm a programmer, with only limited experience in electronics, so I'm not sure how to best accomplish this.
[Overview]
Originally, the radio displays the frequency with a vertical bar (B) that travels over a frequency band (C). My idea is to attach something to that bar (or to the carriage that the bar is attached to), and measure the distance (D) between the bar (B) and the inside wall of the radio. If I could do that with some electronic component, I could get a signal that I could translate into a number that again could be used to select a DAB station.
The problem is that space inside the radio is limited.
Images
This image shows a horisontal, round bar on which the frequency bar moves along. When the radio is fully assembled, the speakers are located on top of this, leaving about 1cm space between the horisontal bar and the speakers. It must also go clear of two lightbulbs (for illuminating the frequency scale).
The frequency bar is sandwiched between the glass dial scale, and a metal plate. Here's what it looks like from above.
Here's the back of the tuning knob and its shaft. As can be seen, there's not too much space here. The knob is dual shaft - the outer ring is the speaker selector.
Here is a birds-eye view of the interiors, when taken out of the enclosing cabinet. And a close-up of the variable capacitor's shaft, as per Transistor's request.
Oh, and here's the schematics, if there are any Norwegian speaking radio enthusiasts out there.
Here are the options I have investigated/tried so far:
  • An ultrasonic rangefinder (like http://letsmakerobots.com/node/30209)
    These are too big to fit. Also, I doubt I would get any sensible signal from it, as there are many parts inside the radio that would reflect the ultrasonic waves. The same goes for infrared rangefinders.
  • A slide potentiometer (like these: http://www.potentiometers.com/select_slide.cfm)
    The ones I have found are difficult to fit, and there are not many that are longer than 10cm. The radio is ~50cm wide, so that would leave most of the band unused.
  • A SoftPot (like https://www.sparkfun.com/products/8681)
    These works by reacting to mechanical pressure somewhere on the surface. They come with an "actuator", which is basically a screw with a round, plastic tip. This was promising - I attached the actuator to the part moving the bar, and let it travel along the softpot membrane. However, the tuning knob is carefully designed so that when the bar reaches one end of the scale, it stops moving, because the wire (E) that drives it will start slipping on the tuning knob to avoid damage. The pressure needed to activate the softpot was enough to cause too much friction, so that the wire was slipping, and the bar did not move.
  • A string potentiometer (like these: http://www.unimeasure.com/). I could attach the string to the bar, and the stringpot housing to the inside wall. However, most stringpots I have found seem to be meant for heavy industrial use, and are priced and dimensioned accordingly. The added friction could also be an issue.
What other options do I have?
  • \$\begingroup\$ Sorry to be the bringer of bad news, but as beautiful as this question is it may be off topic for this site. Please see electronics.stackexchange.com/help/how-to-ask and electronics.stackexchange.com/help/on-topic \$\endgroup\$
    – Voltage Spike
    Commented Aug 9, 2016 at 20:42
  • \$\begingroup\$ Is the original radio still intact and working? If so, why not use the AM band and "listen" to the oscillator to find out where on the dial you are. \$\endgroup\$
    – Buck8pe
    Commented Aug 9, 2016 at 20:58
    \$\begingroup\$ Well, that's part of the fun you wanted! Inside the radio you'll find that the dial is changing a capacitor that is part of a tuned circuit (an oscillator basically). You could try to figure out what frequency the tuned circuit was at and that would give you your dial position. Something to look into? \$\endgroup\$
    – Buck8pe
    Commented Aug 9, 2016 at 21:12
    \$\begingroup\$ I'm sad to hear about the FM radio in Norway. We managed to stop the craziness in Sweden, but just barely. \$\endgroup\$
    – pipe
    Commented Aug 9, 2016 at 21:47
    \$\begingroup\$ @laptop2d: Please leave this question open. It is a design problem and while there may be no one correct answer it's the type of challenge many of us love. It gives a break from answering questions on power supplies for LED strips. \$\endgroup\$
    – Transistor
    Commented Aug 9, 2016 at 22:13
7 Answers 7
You could consider making your own linear pot using a piece of nichrome wire and a sliding contact, preferably precious metal (cannibalize it out of something).
A straight 40cm piece of AWG 30 Nichrome wire would have a resistance of about 8 or 9 ohms. If you put 100mV across it (use a voltage divider from your ADC reference and an op-amp buffer), that's only about 11mA. Then amplify the wiper voltage with a decent op-amp and you're done. Linearity should be excellent (in the 0.1% class most likely).
  • \$\begingroup\$ This sounds simple enough. Nichrome wire seems to be available quite cheap, at least from E-cigarette vendors. \$\endgroup\$ Commented Aug 10, 2016 at 15:46
  • \$\begingroup\$ I got a couple small rolls of 100' AWG30 for < $2 US ea. from China. \$\endgroup\$ Commented Aug 10, 2016 at 16:13
    \$\begingroup\$ Remember that nichrome wire is pretty low resistance. When they make pots with it (either linear or rotary), they typically wrap a long piece around a non-conductive mandrel so that you get enough overall length to make a practical resistance (although it will still be quite low and perhaps unsuitable for a battery-powered circuit.) \$\endgroup\$ Commented Aug 10, 2016 at 16:54
  • \$\begingroup\$ @RichardCrowley That's probably why I went and calculated the actual numbers in my answer above 11mA and 100mV for 0.25mm/AWG 30. Its quite practical in fact, we've used this in production instruments. AWG 30 is also large enough to be reasonably rugged physically. \$\endgroup\$ Commented Aug 10, 2016 at 16:58
  • \$\begingroup\$ Thanks, everybody, for lots of great suggestions! I'm going to start with this one for this project, simply because it seems to be the quickest way to my goal (given my lack of knowledge), and I'd like to have a working DAB radio before they switch off the FM band in January. But for my next radio I'll go the oscillator route. \$\endgroup\$ Commented Aug 15, 2016 at 8:06
My suggestion is that you forget about trying to figure out where the needle is at and build additional circuitry that interfaces with the radios tuned circuit.
You could select the AM band which tunes the internal oscillator from about 500kHz to 1.7Mhz. If you got your hands on the schematics for this radio you could figure out where to put your "tapping" point. The problem is not to load the circuit in a way that would alter the frequency, but that's doable.
It could even be as simple as reading the value of the variable capacitor that the dial is altering.
Doing it this way, you are less likely to deface a beautiful old radio and you'll know a bit about how radios work when it's done.
  • \$\begingroup\$ This sounds interesting, and as you've said, I was looking for fun. I'll just have to look more into how radios work, and, in particular, oscillators. I assume this is oscillator related? At least these "wings" move when I work the tuning knob. \$\endgroup\$ Commented Aug 10, 2016 at 13:04
  • \$\begingroup\$ Yes, that's a large variable capacitor. Is it fixed to a PCB or can you get at its wires? \$\endgroup\$
    – pjc50
    Commented Aug 10, 2016 at 13:08
  • \$\begingroup\$ @pjc50 No PCB here. Wires are easy enough to get to. \$\endgroup\$ Commented Aug 10, 2016 at 15:47
OK, assuming you can detach the variable capacitor from the surrounding circuitry, then it should be a simple matter to read it into a digital system. On your (rather nicely hand-drawn from before the days of CAD) schematic, it's the parts 3326/3327 at the top left just below the antenna.
If you incorporate it into a loop of Schmitt trigger buffers, you can turn the capacitance value into a frequency which can then be counted in software on a microcontroller. Adjust values of R1 until the frequency range is "sensible".
  • \$\begingroup\$ Nice idea. There is at least one capacitance-to-digital chip that could be used directly. \$\endgroup\$ Commented Aug 10, 2016 at 14:10
  • \$\begingroup\$ I had originally hoped I could just add my stuff somewhere, leaving the radio functioning as it was. But your suggestion sounds interesting. \$\endgroup\$ Commented Aug 10, 2016 at 15:50
  • \$\begingroup\$ This approach might actually work if the radio is intact, but I'm not sure. Does it really work with no further maintenance, as a tube radio? It's almost in too good condition to fiddle with at all.. \$\endgroup\$
    – pjc50
    Commented Aug 10, 2016 at 16:11
    \$\begingroup\$ I agree about the idea of trying not to interfere with the original radio as much as possible. If you want a non-destructive approach, I'd start with this one (the cap wires can always be soldered back) and work towards Pete's if you're having no luck. Good luck with it, beautiful radio and great project! \$\endgroup\$
    – Buck8pe
    Commented Aug 11, 2016 at 8:12
    \$\begingroup\$ Also, the nice thing about this approach is that you could use a fixed capacitance for C1 to test your uP code. The frequency of the above oscillator is determined by the product of R and C. If you use a fixed R and C you can calculate the theoretical frequency and test that your uP is producing that figure, ballpark. Then you know you're on the right track. \$\endgroup\$
    – Buck8pe
    Commented Aug 11, 2016 at 8:29
The tuning knob will be driving a variable capacitor. Replace that with an ordinary potentiometer and you should be able to read its value trivially using analogue to digital conversion.
  • \$\begingroup\$ This is by far the most practical and efficient alternative. It beats my geeky, fiddly suggestion! \$\endgroup\$ Commented Aug 10, 2016 at 16:53
Quick answer:
  • use a rotary encoder, axis mecanically connected to the knob axis;
  • leave the frequency scale mechanism as it is.
  • \$\begingroup\$ Could be possible, but that would mean some serious disassembly of the knob, which has a lot of stuff attached to it. Also, it wouldn't give me an absolute value. Since it is possible to continue turning the knob when the bar has reached the end of the band, there would be a mismatch between the bar's position and the station being listened to. \$\endgroup\$ Commented Aug 9, 2016 at 20:19
  • \$\begingroup\$ String encoder is another possibility, but probably overkill and overpriced for your application. \$\endgroup\$
    – The Photon
    Commented Aug 9, 2016 at 20:38
  • \$\begingroup\$ Or if you find a rotary encoder with low mechanical friction, just operate it from the existing belt mechanism. \$\endgroup\$
    – The Photon
    Commented Aug 9, 2016 at 20:39
I would put a grid of Gray Code on the BACK of the dial scale, and a duplicate of the "cursor" on the back to read the gray code with reflective opto sensors. That would tell you the ABSOLUTE position the cursor along the dial scale. And it would be completely STATIC so that the position could be retrieved even from cold power-up.
Another alternative would be to use a tiny stepper motor to a length of threaded-rod ("all-thread" as it appears to be called in Europe). Then you can use that to position the cursor at the direction of the microcontroller.
You could even use one of those "filament LED" strips to make a glowing cursor behind the glass window.
