My ATtiny13A fuses are set to use the internal 128 kHz clock without clock divided by 8.
I found online an ArduinoISP sketch that allows me to program it with that clock speed. But then I uploaded some code with those lines at the start of my main()
to set the clock division factor to 256:
CLKPR = (1 << CLKPCE);
CLKPR = (1 << CLKPS3);
So my clock should normally now runs at 500 Hz. I guess it works, but I now cannot program my ATtiny13A anymore, it gives me unexpected signature error.
I found this ArduinoISP sketch online: https://github.com/lmpipaon/ArduinoISP_slow_SCK
Seems nice but it says it does not work with the 256 prescaler, which is what I need. When I try nevertheless to use the 256 prescaler with 600 baud rate in the ArduinoISP sketch, avrdude (avrdude -b600 -cstk500v1 -P /dev/cu.wchusbserialfa130 -pattiny13 -e -U flash:w:lowVoltage.hex
) still gives me unexpected signature errors.
I also tried adding -B 8000
or -B 10000
with my upload command but apart from giving me different device signatures, it does not upload my code.
