I am now trying to fix a camera control wheel, like the one in the top right corner of this camera (not the one which I am fixing):
This is a cheap part but I cannot find a replacement for my camera model (yes, I have searched thoroughly) and I cannot bet on that whatever else I find will fit in. I have took it apart and I am totally confused.
What I see here is 12 clicks per full rotation wheel (I see the clicking circle grill) with plastic parts. A small PCB has three outputs (three stripes on the bottom) and two grounds (two pins on the sides), the brush set only touches the PCB and nothing else. The brush does not move closer or further from PCB, it is fixed at some distance.
Now, THIS is expected to be able to deduce a click from every 30 degree position change:
https://i.sstatic.net/cftoU.jpg - contact plate, brushes and 120 degree rotation simulation with correct starting position.
https://i.sstatic.net/32skB.jpg - PCB with oil and friction marks outlined
Even more: the contact plates (bright places of PCB) seem to be not conductive at all - measured resistance between two points of same plate is >2MOhm.
How is it expected to work at all given that no details are missing? Is it more than a contact shortening device?
