I use MP2359 (datasheet pdf) to convert high voltage into 3.3V. The input range of voltage is from 4.5V to 24V.
At low input voltages, things seem to be OK. However when I input a voltage of 21V (MP2359 allows 24V max), it sometimes failed to work when start up, the internal MOSFET seem to be punctured, and the output voltage goes to 21V as the same as the input voltage terribly, parts at the output side burned.
Here is my circuit:
The output current requirement is low, about 20mA.
The input capacitor is MLCC 50V 10uF, and the output capacitor is 100uF 6.3V MLCC, they are from Samsung in 1206 package.
1N5819 is in SOD323 (0805) package, and L1 is in 0805 package.
Here is my layout:
So what's going on?
