I've managed to blow a capacitor while doing maintenance on my 1967 electric organ. It's a 80uf 25V. I've done some searching and found that I can replace it with one that has a higher voltage rating but the same farad value. Is there anything else that I need to know before I buy a replacement? I've read some things about ripple current and resistance? The numbers on the capacitor are: B41283-s5806-z2 80uf 25V A 0-507-24 W9
Very likely any 80 µF capacitor you can find today rated at 25 V or more will work fine in this situation. Such a capacitor from 1967 is electrolytic, so already polarized. Replacing it with a 80 µF 35 V, for example, modern capacitor should no result in any problems.
1\$\begingroup\$ EE in training, here. Isn't it true that electrolytic perform better around their rated voltage? So he should go with a 25V? \$\endgroup\$ Commented Jan 28, 2017 at 22:48
2\$\begingroup\$ no always better to have at least 20% margin higher V ratings also tend to have lower ESR \$\endgroup\$– D.A.S.Commented Jan 28, 2017 at 22:56
1\$\begingroup\$ @BrianDohler, I remember being told that electrolytics should have at least 10% of rated voltage across them but I couldn't find much to back that up when I once read around. So I'd say putting a 35V in should be fine. \$\endgroup\$– TonyMCommented Jan 28, 2017 at 22:59
\$\begingroup\$ Thanks guys. I'm not sure where I heard that and I couldn't find anything to back it up either. \$\endgroup\$ Commented Jan 28, 2017 at 23:04
3\$\begingroup\$ @TonyM: There is some truth to what you say. Keeping some voltage on electrolytics helps preserve the oxide layer that is the dielectric. It's not much of a issue with modern capacitors, though. I only mentioned 35 V since that's a common voltage today. I would expect a 25 V cap to already be derated properly in the original design. Changing from 25 to 35 V really shouldn't be any issue. It's not a large change \$\endgroup\$ Commented Jan 28, 2017 at 23:50
A 80µF electrolytic capacitor from 1967 could be easily 120uF back then, and 40µF today. It probably had a much higher internal resistance than modern capacitors. I think any good quality 100µF 25V is okay. You may of course use 100µF 35V or higher voltage. If you still prefer 80µF, that is okay, but I really think that 80µF or 100µF does not matter.
Do you know how old tube radios are repaired ? Every capacitor is cut away and replaced, without testing them if they are bad or still a little okay.
\$\begingroup\$ Not just tube radios. This is standard procedure for vintage valve hifi. \$\endgroup\$ Commented Jan 29, 2017 at 13:41
