We have a bank of LEDs from a flashlight that plug directly into 4.5v. There's 8 LEDs on a circuit. I'm trying to get them to run off a 9v battery by just connecting the wires from the circuit board (it works fine when connected to 4.5v battery pack). So basically I just need to put a resistor in between the 9v battery and the circuit, but I'm not sure which one to use and I don't want to blow the LEDs.
I tried a 270ohm resistor, but they would not light up. I'm thinking that I probably need to add the diode forward current of 20mA together, which would be 160mA, (as there are 8 LEDs in the circuit) this would mean I should use a 33ohm resistor? Is this the right way to think about it?
Can anyone confirm that a 33ohm resistor would make sense in this case, or do I need a different one? It's for a child's project and I don't want to just test it and risk blowing them.
Thank you!
Here's some photos.
FrontBackclose up
  • \$\begingroup\$ Please add a schematic. \$\endgroup\$
    – winny
    Commented Jan 29, 2017 at 19:38
  • \$\begingroup\$ 9 volts is not enough to light 8 LEDs in series, because they require about 1.8 volts each. Try two banks of four in series/parallel with a dropping resistor. And current in a series circuit is the same everywhere. \$\endgroup\$ Commented Jan 29, 2017 at 20:01
  • \$\begingroup\$ @winny I'm not sure how to create an accurate schematic, as I do not know the circuit, so I would just be guessing. I'll try to add some photos of it, I think that might help. \$\endgroup\$ Commented Jan 29, 2017 at 20:02
  • \$\begingroup\$ @MikeWaters but they're running off 4.5v just fine, maybe they're currently in 2 strings of 4? I'm going to post some photos. \$\endgroup\$ Commented Jan 29, 2017 at 20:03
  • \$\begingroup\$ @winny Yes, we either need a schematic or a better description. Are these in series or parallel? \$\endgroup\$ Commented Jan 29, 2017 at 20:06
You can see from the traces on the bottom of the circuit board that all 8 LEDs are in parallel. There is also a 3 Ω resistor in series.
To find the resistor to drop 9 V to 4.5 V you need to know the current. Since you don't know the exact specs of the LEDs used, the best way to get that is to just measure it. The resistance to add is then the voltage to drop divided by the current.
For example, let's say the current is 160 mA with 4.5 V applied. (9 V - 4.5 V)/(160 mA) = 28 Ω.
However, this is a crappy way to use a 9 V battery to light 4.5 V LEDs. A much better way would be a buck converter to make 4.5 V from the 9 V battery. That has two advantages. First, it will use the energy in the battery more efficiently. Second, the brightness won't go down as the battery drains. It will go out quickly when the battery gets empty.
  • \$\begingroup\$ @Passerby what do you think of using a 28ohm instead of a 3ohm as suggested in the above answer? Could the 3ohm blow the LED's? \$\endgroup\$ Commented Jan 29, 2017 at 20:57
  • \$\begingroup\$ Whoever downvoted this, what do you think is wrong? \$\endgroup\$ Commented Jan 29, 2017 at 21:32
  • \$\begingroup\$ +1 2.5 years on to counter the moronic downvote \$\endgroup\$
    – Russell McMahon
    Commented Sep 27, 2019 at 13:32
Every LED in this module is connected directly to both the outer ring (negative) and the inner ring (positive, through a surface-mount resistor). This makes it a parallel circuit.
Unfortunately, the picture that you've included has the red wire covering the markings on the resistor! Without that information, it's difficult to determine what kind of resistor would be appropriate to add for 9V operation.
  • \$\begingroup\$ Thank you, I just added another pic that shows the resistor, it says 3RD or 3RO I think. What does that mean? Is this a 3ohm resistor? \$\endgroup\$ Commented Jan 29, 2017 at 20:40
    \$\begingroup\$ Correct. 3R0 = 3.0 ohms \$\endgroup\$
    – user39382
    Commented Jan 29, 2017 at 22:46
