I'm aware that in Gray code the successive numbers will differ only by one bit. However I'm not able to proceed further.
\$\begingroup\$ Can you write the truth table to convert straight binary to gray code? \$\endgroup\$– The PhotonCommented Feb 25, 2017 at 16:51
\$\begingroup\$ Yeah, I'm aware of binary to gray conversion. Implementation in terms of XOR gates. \$\endgroup\$– FawazCommented Feb 25, 2017 at 16:53
\$\begingroup\$ So, write down the truth table and see which lines are 1's for which output bits. \$\endgroup\$– The PhotonCommented Feb 25, 2017 at 17:01
\$\begingroup\$ But the conversion is not from binary to gray. Gray equivalents for number 'n' and 'n+1' is given. Also how to relate h and g functions ? \$\endgroup\$– FawazCommented Feb 25, 2017 at 17:03
\$\begingroup\$ So if you have the truth table for input 'n', it's very very easy to make the truth table for input 'n+1'. \$\endgroup\$– The PhotonCommented Feb 25, 2017 at 17:29
Show 1 more comment
1 Answer
The question is asking you the value of N where the value of Gx = 1 for N+1.
Map the current state N and Next state N+1 for the 4 bit Gray code
Read off the min term for each next case of Gx = 1
G0 = 0.1.6.7.12.13.10.11
G1 = 1.3.2.6.13.15.14.10
G2 = 2.6.7.5.4.12.13.15
G3 = 4.12.13.15.14.10.11
--> Answer = G2 is correct though they have the terms out of order in the question
\$\begingroup\$ Given g() is a function of H, I think you ought to re-sort the table according to H before numbering the minterms. \$\endgroup\$ Commented Feb 25, 2017 at 18:53
\$\begingroup\$ @ThePhoton. Feel free....it's pure choice. I prefer to work in sequence. \$\endgroup\$ Commented Feb 25, 2017 at 19:26
