15
I was asked to find the four colour stripes of a 1M ohm (tolerance of 5%)
My question now is don't we have 2 options? I came up with:
  • Black(0) Brown(1) Blue(x1M) Gold (5%)
  • Brown(1) Black(0) Green(x100K) Gold(5%)
Is there one right and one wrong or are both of these correct?
33
You are not allowed to start with black except for zero ohm jumper, so only your second suggestion is valid.
  • 14
    \$\begingroup\$ I always breathe a sigh of relief with answers like this when someone new to EE asks a simple question that's surprisingly sharp, and the answer is "Don't worry, the people who made the standards thought of that one!" \$\endgroup\$
    – Cort Ammon
    Commented Apr 2, 2017 at 17:45
What if you wanted the colours of a 1.5 Mohm resistor? Your first option doesn't give any ability to specify a 2nd digit so clearly it is a bad choice. The second option allows colours of brown, green and green meaning 15 x 100 kohm.
  • \$\begingroup\$ Out of interest what exactly would make this a problem? My initial thought is that how you represent a 1Mohm resistor should have no bearing on how you represent a 1.5Mohm resistor. That is why could you not have brown green green for the latter while still having either of the OPs choices for the 1Mohm. \$\endgroup\$
    – Chris
    Commented Apr 3, 2017 at 10:52
  • \$\begingroup\$ @Chris - I have my own first thought and it differs with your first thought. Consistency and simplicity is my main concern. \$\endgroup\$
    Commented Apr 3, 2017 at 14:11
  • \$\begingroup\$ And I guess that is why the rule in winny's answer. I guess you explained reasoning for the rule rather than stating it was actually a rule but it comes across as more of an opinion than a rule - ie that you are saying you should do it that way rather than it being the only actually correct way. \$\endgroup\$
    – Chris
    Commented Apr 3, 2017 at 15:15
