I am learning different voltage to current converters during my bachelor thesis which are a composition of OpAmps and Transitors. The following structure is quite interesting for my thesis and I want to learn it by heart.
In this topology, I can see that if feedback is taken from Emitter to Inverting terminal of OpAmp (with +6V grounded), the output current seems quite stable in simulation and control seems very simple and also that the output voltage of OpAmp is Vbe higher the input voltage in case Rf = R1 (I would appreciate if i would know the disadvantages of that structure).
However, in case if feedback is picked from collector of transistor, as is shown here, the output current Ic is not stable anymore and there is continuous swinging on output current. I can't understand why does this happen. This was already discussed in What does this op amp/transistor circuit do? (revised circuit) from Andy Aka, according to him it happens because of OpAmp gain coupling with Collector gain of transistor which causes it to swings. I need more analysis in this direction- and will be very grateful if someone can suggest any literature on this swinging effect where I can learn it into details !
Secondly, the other problem with this topology is that if my emitter resistance is not constant and is rather a value within a given range calculated for this design, I can't directly calculate the output voltage of OpAmp as compared to former case wehre output voltage is simply input voltage plus Vbe. Is there any other way to calculate output voltage of OpAmp (Base voltage of Transistor) without knowing exact emitter resistance ?
Circuit
Thanks alot for your answers !
  • \$\begingroup\$ When you say "swing" do you mean oscillate? \$\endgroup\$
    – The Photon
    May 5, 2017 at 14:42
  • \$\begingroup\$ Do you know the basic tests for oscillation in an op-amp circuit and have you checked them? This is your thesis work so you should be showing what you know, not what we know. \$\endgroup\$
    – The Photon
    May 5, 2017 at 14:44
  • \$\begingroup\$ @ThePhoton- yes by swing I meant oscillation. I dont know the oscillation tests but would like to learn :) Actually this is a background study of my thesis and at the moment i couldn't find enough literature to learn the basics of how these voltage to current converters with opamps and transistors work and about where are the bottle necks ! \$\endgroup\$ May 8, 2017 at 9:57
Positive feedback occurs when the signal fed back into the input is in phase with the output. A circuit will oscillate when positive feedback causes the loop gain (amplifier gain + feedback) to be greater than 1.
In your circuit the signal is inverted as it goes through the transistor, so it is 180º out of phase and produces negative feedback. However due to capacitances in the op amp and transistor the phase changes as frequency increases.
If only one capacitance was involved then the maximum phase change that could occur would be 90º and the circuit would always be stable. However if several stages have capacitance then the total shift could reach 180º at a frequency where the amplifier still has some gain, causing the loop phase shift to reach 360º - positive feedback! If the loop gain is greater than 1 at this frequency then the circuit will oscillate.
Op amps have several internal stages and very high gain, so to make them stable with feedback one stage may have extra capacitance added to make it the dominant pole. For an op amp to be unity gain stable the gain must go below 1 (0dB) before any other pole causes the phase shift to reach 180º.
If you add another gain stage externally then the total gain is increased and other poles may be reached before the gain has gone below 1. The external stage may also have a pole at a frequency which is within the frequency range of the op amp's dominant pole. Most op amps are designed to have the best possible unity gain bandwidth, so they are only compensated enough to barely keep the other poles below the 0dB line. therefore any significant external gain or phase shift could make them go unstable.
To make this circuit stable you could try using a lower bandwidth op amp, or one which can have an external compensation capacitor added, or create an external dominant pole by placing an RC filter in the feedback loop. However it will still have the other problems mentioned.
Taking feedback off the Emitter is better because the transistor's voltage gain is less than 1 at this point, and it is isolated from the Collector so changes in load impedance have less effect. In Common Emitter mode a bipolar transistor has good current regulating ability all by itself, so the op amp can have lower gain and bandwidth. To get these advantages for current sourcing rather than sinking you just have to swap the transistor from NPN to PNP.
No. Since the load voltage is added to the Base-Emitter voltage, you must know what the load resistance is in order to calculate the op amp's output voltage.
  • \$\begingroup\$ Thanks alot for a comprehensive Answer. It helped alot killing my coufusions ! If I modify this topology a little bit, I am not able to find way to get to a emitter resistance used at a middle stage. Would you like to suggest something in that case ?electronics.stackexchange.com/questions/302124/… \$\endgroup\$ May 8, 2017 at 9:52
