I am using Multisim to design the first stage of an analog signal processing block.
I am using the Op-Amp AD797AR from Analog Devices. I am trying to check if the opamp is inverting unity gain stable.
I have the following schematic
My input is a sine wave of 100 KHz peak of 10 mV but the output seems to be unstable.
How do I ensure stability for the AD797AR? What are some things I can check to ensure stability?
