I have a voltmeter and ammeter combo which sense the voltage and the current at the output. My problem is when nothing connected to the output it shows 0.06V else 0.00V. I tried to connect the output the GND but the value is still the same.
The other problem is it shows a little bit higher value than the real, for example 7.07V the original and 7.10V the displayed.
How can I modify this circuit? The OUTPUT(+) is the output where I want to sense the voltage. The ADC connect to an ADC but no marking on the IC.
The op-amp is LMV358 Rail-to-Rail.
No calibration potmeters.
