Can anyone enlighten me on how to approach this question? I had tried solving it for hours and still doesn't have a clue. The circuit is an overdamped circuit and required to find the parameters. Please help!
If you truly have no idea at all where to start, then you are trying to get into the wrong field. Surely you know something. If not, bail out now.
We can help when you get stuck on something specific, but aren't going to do your homework for you.
Hint: You can combine the voltage and the current source into a single equivalent source. Look up Thevenin and Norton sources. You can go further and combine that with R3. I would simplify the whole thing to a Thevenin source driving a parallel LC, with the appropriate initial conditions.
  • \$\begingroup\$ Thank you so much for the hint. I am trying to solve it now and you are right, I think I do know something after reading your hints. Not gonna bail out and I will give my best. Thanks again! \$\endgroup\$
    – user165363
    Commented Oct 10, 2017 at 11:22
