I want to design a very simple high side switch, using components already present in the bill of materials of a larger project. I do not want to choose special components, but just try to re-use what I got, to simplify production and reduce related costs. The switch needs to drive high-side a standard 3-wire Fan, one terminal being the (-), the other being (+) and the third one being tachometer signal. The Fan is rated 12V, 3.6W. The idea is to drive two fans in parallel with the same circuit. The output voltage to the Fan needs to be linearized, since I want to be able to read the tachometer without any difficulties. The output voltage needs to be controlled by a micro in PWM, using 62,5 KHz carrier frequency, 5V logic. Here's the simple circuit I have been working on:
Do you see any flaws in this circuit?
