Consider a pair of solenoid magnets as shown in the figure. Based on the magnetic field (B) at each point and corresponding Current Density, (J), I can calculate the Lorentz Force density at each point as F = J x B. Since it is a solenoid (axisymmetric), if I consider, say YZ plane, I can get axial force density as Fz = Jx * By and radial force density as Fy = Jx * Bz for each discrete point in the coil.
From this Force density map( vectors at each point), how can one calculate the net force in each solenoid? My intuition was adding all the values in a face, and multiplying it with the area of the face will give the force in that face. If it is correct, how do I find the net force in the body? multiply it by 2 pi?
  • \$\begingroup\$ Do you actually mean "based on the magnetic flux density (B) at each point" or are you referring to some point in space called "B"? \$\endgroup\$
    Commented Feb 1, 2018 at 10:33
  • \$\begingroup\$ @andy aka B is the magnetic field (magnetic flux density) at any point. \$\endgroup\$
    – Sankar Ram
    Commented Feb 2, 2018 at 6:21
I had considered a standard solenoid from literature, where the final value from is known. The force density at different points was calculated and I could find out the method to correctly evaluate the net force.
If you have data at N points, your total area is A, R is the average radius, r is the radius at a given point, the net force can be given as,
\$ F =( \Sigma f ) \cdot 2 \cdot \pi \cdot R \cdot \frac{A}{N} \$
A bit more accuracy can be gained by
\$ F = \Sigma (f \cdot r) \cdot 2 \cdot \pi \cdot \frac{A}{N} \$
Yes, basically that's what you have to do.
The mathematical term for that is integrating the force densisty over the area and about since Leibniz's time it is written as
\$F = \int_A f da\$
(where \$f\$ is force density [unit force per unit area]; \$da\$ is the infinitesimal area element; \$A\$ is the total area and \$F\$ is the total force)
BTW: the \$\int\$ is to remind of Sum.
  • \$\begingroup\$ Since in my case, f is not a continuous function, but discrete points, should it be \$F = \Sigma f \Delta a\$ \$\endgroup\$
    – Sankar Ram
    Commented Feb 3, 2018 at 10:23
  • \$\begingroup\$ Yes. That's the finite approximation for the infinite sum (=integral). \$\endgroup\$
    – Curd
    Commented Feb 3, 2018 at 10:42
If you have calculated all the force densities in discrete points over the face and multiply with the face area, you still need to integrate along the solenoid's radial direction for the required volume integration.
Therefore, multiplying with 2 pi is not suficient, you have to multiply with 2 pi x radius, where radius is an averaged radius.
Assuming you numerically calculated the force densities in the points, and going through the volume integration, you get
radius = (rad_outer + rad_inner) / 2
with outer and inner solenoid radius.
  • \$\begingroup\$ So, area*2*pir is the volume of the solenoid, right? Would it be more accurate if I multiply pi (OR^2-IR^2)*Axial width? \$\endgroup\$
    – Sankar Ram
    Commented Feb 3, 2018 at 10:20
  • \$\begingroup\$ Yes, it requires a volume integration. And both expressions (mine and yours) are exactly the same, the same accurracy, therefore. \$\endgroup\$
    – UweD
    Commented Feb 3, 2018 at 10:53
