I want to use anti-aliasing filters in different scenarios. Below is the topology for how to use a passive LP filter in the case of a single ended transducer and single ended data acquisition:
How should the RC the connection be:
1-) If the source is diff ended and the data acq. is also diff ended?
2-) If the source is single ended and the data acq. is diff ended?
Could you illustrate these two cases by drawing like mine above.
Edit regarding an answer:
