With the fairly recent emergence of the Arduino/Raspberry like boards, I have a new found interest in circuits/electronics. I took some introductory classes back in undergrad and I'll be honest, it was rather difficult. That being said, I feel my question is rather simple for a seasoned electrical engineering, but I'm having a hard time finding a straight answer.
When I buy a breakout board that consists of an integrated circuit (IC), often there are capacitors, resistors, etc. placed inline with the header pins. What purpose do they serve? Why don't they put those components in the IC to begin with? The seller of the breakout board does generally forward datasheets on the IC itself but there isn't much said about the additional capacitors, resistors, etc.
Hypothetically, lets assume I wanted to build my own breakout board for a Arduino/Raspberry based on a select IC. How would I know what additional capacitors, resistors, etc. are needed to make the breakout board functional? What kind of questions do I need to ask myself in order to layout the circuit(s) connecting the IC to the header pins? I know it's dependent upon on the IC and the target board, so I'm not looking for a specific answer, but what if I change the target board? What if I change the IC? How do these influence the design?
Basically I'm trying to get a better understanding of the additional capacitors, resistors, etc. found on breakout boards. I can do more research on my own, but I would at least like to get a general explanation to help guide me with further research.
  • \$\begingroup\$ Capacitors, at least, are difficult to manufacture by the same processes they use to make integrated circuits. It's easier and cheaper to just have them separate components. As for the resistors, they could be configurable; the devices might do different things depending on the resistor values (consider an op amp with its feedback network, for example) \$\endgroup\$
    – Hearth
    May 17, 2018 at 3:34
Many times, what you are calling a breakout board is in fact a complete circuit.
The other parts are all the things needed to make it work - often implemented from a recommended circuit in the datasheet.
A breakout board in the usual sense is just a board where you can attach a small or complicated chip and have manageable connections using wires or breadboard pins.
You figure out what goes on the board by looking at what it takes to make a functional circuit (supply voltage, needed control signals, additional components, etc.) you get that from the datasheet.
Then, you look and see what your main board (Arduino or whatever) can supply.
Suppose, for example, your external chip needs 3.3V. Well, there's 3.3V available from the Arduino. Fine. Only, the chip is a 24 bit ADC. The 3.3V from the Arduino is really nasty, so either include a separate regulator on the breakout board, or heavily filter the 3.3V from the Arduino.
Now, the 3.3V power for the ADC means that it also uses 3.3V logic levels. Can the Arduino accept those? Can the ADC tolerate the 5V logic level from the Arduino? If not, include logic level shifting on your breakout.
Then, you get general design principles.
In our example of an ADC, we will need decoupling capacitors on the ADC power pins. Pretty much any chip needs this. Either to prevent its switching noise from disturbing other parts, or to prevent noise from other parts causing a problem to the chip you are looking at.
So, there's a lot that goes into it. There's no simple "sprinkle a bunch of resistors and capacitors over it like pixie dust" solution.
What you need for an ADC is different from what you need for a relay driver is different than what you need for a sensor is different from other stuff.
Case by case, whatever is needed/required to make it work and make it safe.
In response to comments from OP:
Many datasheets include example circuits. Often times, the examples are also the circuits used when the manufacturer measured the real performance of the chip - following those recommendations should get performance as in the data tables in the datasheet. Good datasheets also mention why certain parts were chosen.
So, when designing a breakout board (or any other circuit using a particular IC,) you start by looking the datasheet and the examples it gives.
Regardless of whether or not the datasheet provides an example, you will have match the connections of the breakout to what the base device expects and provides.
Since already have your base device selected (Arduino or Pi or whatever,) get familiar with it first - what signal levels it expects, what power it can provide to external devices, how it can talk to external circuits, etc. Then, you look for an IC or circuit that provides whatever function you need. Find one that matches your functional requirements, and that also can easily talk to your base device.
Maybe you will find that no IC that meets the functional requirements can easily talk to your base device. Well, you can either add circuitry to make it possible (say, level shifting so a 1.8V IC can talk to a 5V Arduino.) Or, you back up and reconsider the base device - it might be simpler all around to use something that can natively address your external device.
So, pick one end and work it through from there. You might end up making a couple of loops back and forth - well, it happens.
You can use programs like LTSpice to simulate circuits before you build them, but they won't all contain models of all ICs. I'm not a big fan of them. They all have inaccuracies somewhere, and as a beginner (or hobbyist like me) you won'necessarily know when a circuit is failing because it is bad or because you've hit one of those odd wrinkles in the software.
Pick something interesting, and see what it would take to accomplish it. Use available modules to begin with - this gets you some success and visible progress.
See how the modules function, and how they are designed.
On your next project, consider something that needs a simple external circuit. Look at how others accomplish it, then put together a circuit that you think will work. Build it on a breadboard or perfboard to test it. Fix it, improve it, have a PCB made so that you can install it permanently in your device.
You can post circuits here and ask for help when they don't work (or don't work right.) But, you should post your circuit diagrams (and often times the layout or a picture of your breadboard) when you do. Ask direct questions rather than open ended ones. (Bad: "Critique this five page circuit diagram." Good: "This amplifier is oscillating. Here's the circuit. What have I done that makes it unstable?")
  • \$\begingroup\$ I like that your answer is expressed in the form of an example. From what I gather here, as well as in other answers, the datasheets often do provide an example circuit to interface the IC. I would hope that they also provide some logical explanation as to why they chose the circuit they did? Maybe it's implicit, where they assume knowledgeable people will be working with their IC. Either way, I would use their recommended circuit and adapt it to fit the target board following the same logic? \$\endgroup\$ May 17, 2018 at 22:33
  • \$\begingroup\$ OK, let's assume the datasheets don't provide any info for the circuit design. The IC and the target board both provided features/functions. Is the circuit design focused on making sure the target board functions/features are "altered" to meet the requirements of the IC? Or is it the other way around? Obviously it must work at both ends, but where do you generally start with the design...the target board or the IC? \$\endgroup\$ May 17, 2018 at 22:48
  • \$\begingroup\$ Also, I'm guessing there is no one right answer, but surely there are better answers than others. Is this forum a good place to post a design for recommendations/critiques on a design? Is there a software out there does simulations of circuit designs to check it's functionality as opposed to physically building the circuit and testing it? What is the "modern" approach/recommendation for someone like myself trying to get back into learning circuit design (aside from reviewing text)? \$\endgroup\$ May 17, 2018 at 23:03
Sometimes, components are external to the IC because they're difficult or expensive to make with the IC process. Sometimes external components are use to program the IC to do certain things.
Capacitors are two conductive plates of a certain area, separated by an insulator. Area, real estate, is expensive in an IC, and multiple layers, number of processing steps, is also expensive. The dielectrics available that are compatible with the silicon process only have low K. All this means that values above a few pFs are usually implemented off-chip for preference.
Although sets of the standard process resistors on chip track very well, they have a very poor absolute tolerance. If anything better than a few % accuracy is needed, it's usually cheaper to put that resistor off-chip. The standard resistors sit in a well, and so cannot go outside the power rails. An isolated resistor is possible, but takes more area and so is more expensive.
A part will often be sold with 'pin programmable' functions. External components will be needed to set voltages and currents on certain pins to control these.
All ICs have some degree of input protection, almost always diodes from pins to rails. An external series resistor can improve the power handling of these significantly, by limiting the maximum current that can flow. This can be useful on a breakout board designed to be handled/used by amateurs.
A breakout board is designed to ease interface functions for some limited purpose. A VLSI digital IC such as an ARM chip will have a great deal of analog components inside for clocks and PLLs, but rather than limit analog functions inside they are left for use interface design for additonal input protection, output indicators, input filters, output current limiters, opto-isolators or user timing components, power on reset time, level shifters etc with tradeoffs in choices made for each.
An IC is designed to fill a market need for specific functions with the widest multipurpose variations for analog and some variations for clock setting on digital features for example. Of course filtering must be done externally to optimize cost and placement of parts as IC's are limited to what C values can be inbuilt and silicon real estate and process complexity affects IC cost.
