I see an AC mains input but I have no idea what kind of cable it goes to, how do I find the cable type so I can design around that? (Or conversely I have a cable and I don't know what type it is)
7
Look for IEC320 reference tables, the connector should match one of the international standards. Once you identify the connector you can search for it. If not, it is a custom cable and the manufacturer will need to be contacted.
The first edition of IEC 320 (later renumbered IEC 60320) was published in 1970. Source: Wikipedia
This is what a table looks like
enter image description here Source: https://www.stayonline.com/reference-iec320.aspx
Edit:
Another good resource https://www.plugsocketmuseum.nl/ApplConn_overview.html
In addition to the IEC connectors @laptop2d listed, there's a few others that are also in common use.
Ceeform connectors are frequently used where high power and/or water resistance are needed. There's a whole series of them for 1/2/3 phase connections at different voltage and current levels.
Ceeform Inlet Connector Ceeform Plugs
Neutrik PowerCon connectors are also becoming more common, particularly on professional audio devices
Neutrik PowerCon Inlet Neutrik PowerCon
