I have a non-standard Power over Ethernet application (connector, and devices are not ethernet standard but we are using ethernet pairs and protocol for communications). On looking at PoE schematics I have noticed that none of them incorporate common mode termination in the design. Isn't common mode termination needed at all, or does the PoE standard reduces maximum cable runs to compensate?
I was planning to use the following circuit for termination (with its equivalent on the ground side, values are estimates), is this overkill?
