I have a magnetic wire and I want to use it to make an electromagnet. The electromagnet will be powered by a 5V, 2A power supply.
How do I know what resistor should I use in series in order to avoid damaging the power supply?
I suppose that I can use Ohm's law, which would mean that I would need a 2.5 Ω resistor. Since the resistance of the wire itself is 0.5 Ω, it means that a 2 Ω resistor would be enough.
I also suppose that if I use a higher resistor, such as 4.7 Ω, the electromagnet would be less powerful.
Am I right, or have I missed something?
  • \$\begingroup\$ That sounds like a good plan. You need to make sure the magnet wire doesn't get too hot, but being prepared to disconnect it quickly is probably sufficient.. \$\endgroup\$
    – user80875
    Commented Mar 29, 2019 at 23:34
    \$\begingroup\$ The magnet would be more powerful if you could wind more tunes on it until its resistance was 2.5ohms and no resistor. Can you put any more turns on the magnet? \$\endgroup\$ Commented Mar 29, 2019 at 23:37
  • \$\begingroup\$ If you are concerned with the electromagnet to be "powerful" with a given power supply, you need to get your magnet (not "magnetic") wire 5 times longer and don't waste any power in external resistors. What size of coils do you plan to have? \$\endgroup\$ Commented Mar 30, 2019 at 2:31
  • \$\begingroup\$ Two methods you might use are to start with a high resistor and work down until the coil starts to heat up too fast, or to start with one AA battery, test, add one, test, add one. If your current is DC, it's the resistance of the coil that will determine the value it settles on, so you can measure DC coil resistance(just hold the leads on the coil until the resistance value settles out, this takes a while for high inductance coils) and estimate acceptable voltage based on that and the magnet wire's ampacity. A cheap variable voltage regulator would be a good option too. \$\endgroup\$
    – K H
    Commented Mar 30, 2019 at 3:20
  • \$\begingroup\$ Bear in mind the plumpness of your core and shortness of magnetic circuit will determine your maximum magnet strength. Having an outer shell of similar-to-core cross section around and at the back of the magnet is idealish. \$\endgroup\$
    – K H
    Commented Mar 30, 2019 at 3:28
Your resister choices are reasonable so there will not be overcurrent on the PSU .This does waste lots of power .The resister wastes more power than the electromagnet .You could consider a lower voltage power supply or rewind the electromagnet with more turns of smaller diameter wire.
On actual testing, you will discover the coil actually has a somewhat higher impedance than the actual wire resistance, but practical coil impedance is hard to calculate... So once you've built it, you may need to adjust the resistor value. (E.g put more resistors in parallel with the big 2 ohm).
  • \$\begingroup\$ Impedance is largely irrelevant for a DC current such as that typically used in an electromagnet. If it's powered by AC, then this will of course have an effect. \$\endgroup\$
    – TerrorBite
    Commented Jun 30, 2023 at 12:36
