I'm wondering if a switch exists that fits this functionality I imagine:
The user would depress the switch, it would latch and stay depressed. Once the product completes its function, the control circuitry sends a signal to the switch which un-latches it. I imagine the actuator could be spring loaded so it would pop back up, or maybe a solenoid pushes it into the open state.
I wouldn't even mind having to supply current to a solenoid to keep the switch depressed. That is what most toaster actuators do. In fact, what I want is exactly what a toaster does. But I want to avoid investing time in designing a custom mechanical solution for this.
Can anyone confirm that such a product exists in a form factor like a standard panel mount switch?
Some words I can think of to describe this are: Electrically toggleable switch Latching switch with electric reset Switch and latching relay combination Electrically controlled switch
I've searched around with these and other terms, but haven't found anything.
Here is what I imagine the circuit symbol would look like:
Thanks for your help.
