For the below circuit, VIN = 12V. (using 220V to 12V adapter) and frequency of 3.3V PWM signal : 500 Hz
In the below case we have two white light strips connected in parallel which will result in total of 4A of current. The issue is the MOSFETs (Part no: TSM240N03CX RFG ) which we are using is not able to support 4A of current. You can check the datasheet
So, can you suggest me the possible design changes that are required in our circuit such that it will support 4A of current.
  • \$\begingroup\$ It sounds like you just need to find a MOSFET that can be driven with 3.3V and will sink over 4A. Have you tried replacing the MOSFET? \$\endgroup\$ Commented Jul 24, 2019 at 11:25
  • \$\begingroup\$ According to the datasheet, the MOSFET can conduct up to 6.5A!? \$\endgroup\$
    – Daniel K
    Commented Jul 24, 2019 at 11:41
  • \$\begingroup\$ Maybe you need a heat sink for the Mosfet? \$\endgroup\$
    – Aaron
    Commented Jul 24, 2019 at 20:37
  • \$\begingroup\$ @DanielK - 6.5 amp capability is likely only be true when the gate is driven with something more than 3v3. \$\endgroup\$ Commented Jul 25, 2019 at 16:01
  • \$\begingroup\$ Likely you should consider using a larger MOSFET (this is a physically tiny SOT23 part), boosting the gate drive, or use one MOSFET for each load. \$\endgroup\$ Commented Jul 25, 2019 at 16:02
Rds(on) is not guaranteed with 3.3V drive and the specifications are rather on the optimistic side even with proper drive. At 4.1A the dissipation could be in the 0.85W range which is very high for an SOT-23. 1.56W is purely a theoretical number. Rds(on) is specified at a given Vgs and it increases significantly (about 50% typically) at maximum Tj, further increasing the \$\text I^2\text R\$ power dissipation.
I suggest a beefier MOSFET designed for 3.3V or less drive, for example an AON7524 which will dissipate around 100-120mW with 4.1A drain current flowing, barely enough to get warm if you give it a square inch or so of copper.
You should not get much in the way of switching losses at only 500Hz with a zero ohm gate resistor, but if you add a larger resistance in there you will increase switching losses. Beefier MOSFETs tend to have more gate charge so they switch more slowly for a given amount of available gate drive current. Something to keep in mind if you're thinking of increasing PWM frequency. At some point a gate driver circuit capable of driving peak currents in the amperes rather than mA or tens of mA becomes desirable.
Actually the datasheey says it DOES support 4.1amps at Tc100°, and 6.5amps at Tc 25°.
Having said that, two obvious options are-- 1) use a higher rated mosfet. Part number will be easy to find. 2) connect your LED strips in series and use a 24 v power source.
Alternately, you haven't mentioned your pwm duty cycle. If this is lowered, you might still get desired brightness at lower average power.
Lastly, also not mentioned is how you are controlling this current?
Is this a theoretical design or a practical observation?
    \$\begingroup\$ Your initial claim about current capability is a bit dubious, as it overlooks the role of gate voltage in the degree to which the device is turned on, and the degree to which the device is not fully "on" in increasing the losses which create heat. \$\endgroup\$ Commented Jul 25, 2019 at 16:07
  • \$\begingroup\$ @Chris Stratton It's not "my" claim - I'm just reading from the datasheet. I am also assuming the OP is knowledgeable enough about switching time Vs heat generation. \$\endgroup\$ Commented Aug 2, 2019 at 7:18
  • \$\begingroup\$ Interesting how Spehro Pefhany answer recommends a MOSFET which has 7x higher gate capacitance, though I admit that the much lower Vgs(on) is a very valid point. \$\endgroup\$ Commented Aug 2, 2019 at 7:30
