I'm learning electronics and found this question below, which is exactly what I've been questioning myself. But there was no good answer there, so maybe someone here can help.
Original question:
Suppose you have a 9 V battery that you connect to a load having a very low resistance (e.g. 0.1 ohm). From Ohm's law, the current would be I = V/R = 90 amps, which seems impossible to obtain from such a battery. If we suppose that the load will not burn, which of these options is the correct one?
1) The battery has a maximum power it can provide. For example, if this power is P = 100 W, then since P = RI^2 the current will be I = (P/R)^0.5 = 31.6 amps and the voltage V = RI = 3.16 V.
2) The battery has a maximum current it can provide. For example, if this current is I = 5 A, then V = RI = 0.5 V. I am aware the values given for P and I might not be realist.
I am just interested in the general behaviour of a battery (is current, power or voltage the fixed value?). Thanks for your help.
Source: https://www.physicsforums.com/threads/maximum-power-current-for-a-battery.96159/
So far I've read datasheets for some batteries and found some intriguing data about how a battery behaves, given certain circumstances such as temperature, load (current discharge), and average voltage.
Beyond these factors, I'm trying to understand if there's a definitive quantification of the total "energy" of a battery? Since mAh, Wh and Joules seems to vary depending how the discharge occurs.
For example, this datasheet from energizer shows that the mAh capacity changes as a function of the discharge rate. If that's the case, is the 'total cell energy' varying?
Thank you.
