I am looking for a circuit that can translate phase difference of two sinusoidal signals (operating at ~1MHz) to analog voltage swing of 0 - 5V.
The signal A & B comes from the capacitors of two different RLC circuits.The conditioning circuit should not load the circuit as it will change the RLC filter circuit operating point.
I could think about digitizing sine signal + EXOR + filtering but, the RLC capacitor that I am using is about 50pF and using MOSFET for digitizing didnt help as gate input capacitance did change the operating point of the previous stage.
Another option, I was thinking is using a voltage follower opamp + EXOR + filter and I am looking for opamps that can have inputs > 20V with supply voltage of 5V and operating at >1MHz. Any ideas?
Additionally, I came across CD4046B, but I believe that it also needs digitizing before it is fed into the signal & comparator Inputs.
Thanks in advance!
EDIT1:
Below is a rudimentary circuit (Please ignore part numbers). If the loading is limited to a few 10uAs, then I beleive the operating point would not shift that much.
