We have a source (Z_s) and load (Z_load) connected with a transmission line. It is known that the connection is matched, that means Z_s=Z_0 and Z_0=Z_load. If the voltage from source is 1V, what will be the voltage on load?
It may look as a textbook exercise, but it's not. I'm having hard time understanding what is going on if we place a matched transmission line between source and load. All the books I have focus on reflections and physical details, but not much about more simplistic real scenarios.
If the connection is matched as described can the transmission line be ignored (considering it's loseless) and voltage on load be calculated from standard voltage divider? Thus, getting 0.5V on load, or do we need to consider the line also and it's 1/3V on load?
