I will be turning a relay on from my circuit by sending a signal 500ms to 1000ms long, and i am trying to protect against poor wiring or faulty relay from the user that causes a short circuit on the relay which could blow the fuse on the module
The power supply is rated for 2A and the fuse on the module is rated for 1A. I would like to create a protection that even if there is some short circuit on the relay output the fuse cannot blow,
My solution was to add a resistor on series of the relay, but this would mean that resistor should have atleast 5watt rating for it to survive, or a high value resistance for it to survive. Having a high resistance also might mean that the relay might not turn on because there wont be enough voltage that will cross it.
Paralleling a resistor to the relay seem kinda useless also since the current will not flow to the resistor but to the short instead.
How should i approach this? i possible how can this be done with basic components (resistor,capacitor,diodes etc)
