I try to learn I2C with this diagram as an exercise. I want to read my ESP8266 IO events from my 5V adafruit trinket.
I2C MASTER ESP8266ex
Operating Voltage 2.5 V ~ 3.6 V
Operating Current Average value: 80 mA
I2C SLAVE TRINKET 5V
On-board 3.3V or 5.0V power regulator with 150mA output capability and ultra-low dropout.
Up to 16V input, reverse-polarity protection, thermal and current-limit protection.
I read on i2c-bus.org voltage-level
Since I2C is an open drain concept the VCC level as such is not critical for the operation as long as all components on the bus can accept the voltage on the IO pins and are able to detect the logic levels.
It's seems to be not the case here, the ESP8266 only accept 3.6V max and trinket use 5V, then I search a solution : bi-directional-logic-level-converter-hookup-guide With my Raspberry as 3.3V power source for LV and the Trinket 5V OUT pin as 5V powersource for HV.
This tutorial use the N-channel BSS138 but i have not this MOSTFET only the N-channel 5ln01sp
This my schematic for the moment :
Can I use the 5ln01sp MOSFET instance of the BSS138 ? (I suppose that yes after having consulted the data sheet of each one but I am not sure because of my low level of knowledge.)
As a beginner, could my scheme work without drawbacks, did I forget something ?
Thank you for your help and your time.
