I am trying to get some stable output from a Brushless power generator/motor/turbine which i purchased from Aliexpress
Mini Micro Small 3 Phase Turbine
To check if it works i tried to rotate it and LED blinks.
Added some toys gears in front of it and running it fast i am able to run over 7 3/5 mm leds so looks like it is generating around 10 Volts with a current of around 150+ milli amperes.
Now i want to get a stable voltage something like 5 Volt so i added a Voltage IC 7805 and then added couple of LEDS. I still didn't added a capacitor as was not sure how much value of capacitor i really needed.
So it is like this Turbine -> 7805 -> 5 mm Led - no other electronic component
In this case when i run the motor - the LEDs just blink for once (0.5 seconds) and then unless the motor fully stops then didn't blink at all. And if it run it again it again just blink for a second.
Is i am missing only the capacitor and what about what value? or something else is needed more to prevent damage to IC/Motor like some diodes etc?
I am also curious that my cheap Multimeter (under $10) does not show any voltage out of the IC and of motor but works for AAA/AA etc.
Any ideas are appreciated
